Boxster shifter console |
partwerks |
Oct 29 2014, 07:57 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
For anyone who would happen to have a Boxster shifter, would there be some pictures that could be shared as to the layout/ideas on how the console was set up in the cab?
Mike Bellis |
Oct 29 2014, 09:36 PM
You don't need the console. I used the shifter and made a console with a wire frame and fiberglass mat.
It has 4 mounting holes so you can bolt it down. I made the linkage on the tranny side. Mine was the Audi version and did not come with the Boxster setup. Finished cover. I cut the Boxster shifter handle down and added a Mustang shifter handle. This allows a screw on knob. The stock Boxster knob sucks. |
partwerks |
Oct 29 2014, 09:43 PM
Thanks Mike.
I can't tell in the 3rd picture, but is there room for the 3rd seat cushion in behind the console, once it is ultimately put in place? |
Mike Bellis |
Oct 29 2014, 09:58 PM
You could build it that way. The cables are in the way. Mine dive into the tunnel before the access panel. I could slide the entire thing forward but i fit best where it is.
You could build a better fitting console than trying to fit the Boxster unit. |
partwerks |
Oct 29 2014, 10:13 PM
I forgot about those cables going to be in the road.
How's come the cables were not routed through the access hole instead? |
Mike Bellis |
Oct 29 2014, 10:20 PM
barrym |
Member Group: Members Posts: 88 Joined: 12-October 14 From: Australia Member No.: 18,008 Region Association: None |
if you're looking for a shifter for a cable shift conversion - check out the lotus elise / exige shifter
http://www.autobahnpower.com/images/Blog/L...fter1%20abp.jpg the '06 onwards is the on pictured above - the '05 and below is the same function, just a little more flex in the cage. |
partwerks |
Oct 30 2014, 07:22 AM
I have the shifter, and cables, just looking for ideas on how to make some sort of housing for the shifter, if I don't use the original console that it would have come with, to make it look decent.
76-914 |
Oct 30 2014, 08:06 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,485 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Mike Bellis |
Oct 30 2014, 02:10 PM
Those are not Boxster cables...
mr2by4 |
Oct 30 2014, 02:43 PM
Member Group: Members Posts: 182 Joined: 9-December 07 From: Fort Worth Member No.: 8,439 Region Association: Southwest Region |
Toyota MR2 also uses cable shift and can be had for a bit less $$ than either of those. I would imagine that, in its 3rd generation, its operation is similar to that of the Lotus (since they shift the same gear box).
Mike Bellis |
Oct 30 2014, 03:26 PM
Partworks has a Boxster tranny, Boxster shifter and Boxster cables.
I believe he is wanting info on finish mounting and console aesthetics. I don't think this is a debate on which shifter to use. What he has is plug and play. |
Chris914n6 |
Oct 30 2014, 05:04 PM
Jackstands are my life. Group: Members Posts: 3,302 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I have the shifter, and cables, just looking for ideas on how to make some sort of housing for the shifter, if I don't use the original console that it would have come with, to make it look decent. There is some good stuff on youtube. 1/4" fiberboard, sintra, or fiberglass is the most common. |
El Vikingo Tropical |
Oct 30 2014, 05:45 PM
Newbie Group: Members Posts: 39 Joined: 10-October 14 From: Canary islands Member No.: 18,003 Region Association: None |
I use the Boxster shifter on a Audi trans and it's work well.
Lo-Fi Version | Time is now: 19th April 2024 - 01:28 PM |
