do i have the wrong 914-6 rear brake pads? |
siverson |
Oct 29 2014, 09:30 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
the large (upper) retaining pin does not fit through the hole in the pad.
wrong pad or should i just make that hole larger? Attached thumbnail(s) |
Dave_Darling |
Oct 30 2014, 11:17 AM
I'm not sure that anyone makes pads with the asymmetric holes any more.
--DD |
mskala |
Oct 30 2014, 12:13 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Also note that PMB is making the 914-6 rear calipers in aluminum, which
has all holes for pins the 'small' type. Then pads work without modifications. I had the reverse problem, had some new pads that I had drilled and went to install in the fancy new calipers and doh! |
Lo-Fi Version | Time is now: 17th May 2024 - 04:10 PM |
