> 1.7 idles a little high
karmann
post Oct 30 2014, 04:05 PM
Took my newly acquired 1.7 914 for a drive, when I started it ideled at about 1100 revs, once warmed up it stayed about the same revs, should I just adjust the idle or something else? It's a standard 1.7 with FI
Cfletch
post Oct 30 2014, 04:09 PM
either that or a vacuum leak. on my 1.7 i had a really bad one where it went from 1k-2500k every few seconds at idle
Bob L.
post Oct 30 2014, 04:47 PM
...Or the AAR is stuck partially open. Essentially a small vacuum leak. If it's not cold outside the AAR shouldn't matter for warm up. Just adjust the idle screw.
JawjaPorsche
post Oct 30 2014, 04:53 PM
I have a 1.7 and I had idle problems too. I replaced all my vacuum hoses and it now idles around 800.
Since you are on the big island, VW shops should have hoses you need.
- Lo-Fi Version Time is now: 30th July 2025 - 09:49 PM
