1.7 idles a little high |
karmann |
Oct 30 2014, 04:05 PM
Newbie Group: Members Posts: 31 Joined: 9-August 13 From: Cheshire UK Member No.: 16,227 Region Association: None |
Took my newly acquired 1.7 914 for a drive, when I started it ideled at about 1100 revs, once warmed up it stayed about the same revs, should I just adjust the idle or something else? It's a standard 1.7 with FI
Cfletch |
Oct 30 2014, 04:09 PM
Member Group: Members Posts: 104 Joined: 30-January 14 From: Santa Barbara Member No.: 16,941 Region Association: Southern California |
either that or a vacuum leak. on my 1.7 i had a really bad one where it went from 1k-2500k every few seconds at idle
Bob L. |
Oct 30 2014, 04:47 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
...Or the AAR is stuck partially open. Essentially a small vacuum leak. If it's not cold outside the AAR shouldn't matter for warm up. Just adjust the idle screw.
JawjaPorsche |
Oct 30 2014, 04:53 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I have a 1.7 and I had idle problems too. I replaced all my vacuum hoses and it now idles around 800.
Since you are on the big island, VW shops should have hoses you need. |
Lo-Fi Version | Time is now: 5th May 2024 - 05:16 AM |
