Was center console available in '72?, If not how do you wire in the 2 gauges and clock? |
stevegm |
Oct 30 2014, 05:48 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
Was the center console available in '72? I am considering adding one to my car and am wondering how I would wire it in if it was not an option in that year, because the wiring would not already be there.
r_towle |
Oct 30 2014, 07:42 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
For wiring, pull up the carpet on the center Tunney at the shifter.
Should be a multi prong plastic plug, or I think more than one. They are tucked into the tunnel grooves with the other wiring. Those are for the center console gauges. Clock is just wired to the fuse box. |
Steve_R |
Oct 30 2014, 08:41 PM
Member Group: Members Posts: 68 Joined: 8-August 12 From: San Diego, CA Member No.: 14,777 Region Association: None |
I made a harness using these diagrams.
Attached image(s) |
JeffBowlsby |
Oct 30 2014, 08:59 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
A 72 does not have the center console wiring. 73-76 only.
That center console is available already built from a couple sources, far easier than custom building it. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:01 AM |
