Help! just lost my tach, wipers, voltmeter, fuel gauge, 11-03-new question: how to id. the fresh air fan wire ----- (solution: always check and recheck fuses- #9 (4th from right) was off center not in tight |
DRPHIL914 |
Oct 31 2014, 04:19 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Don't know what happened- I also had lost my dash lights earlier, put in a new #7 fuse then o.k. then about 30 minutes later I ooze all that stuff and the center console everything - volt meter oil temp gauge and a/f meter all out- what to check first!
DRPHIL914 |
Oct 31 2014, 04:30 PM
Voltage while running is 13.5, -
Could this be an ignition switch going ( no issue starting) , or a bad light switch? Or a short at the tachometer?. |
Lo-Fi Version | Time is now: 18th May 2024 - 03:41 AM |
