Help! just lost my tach, wipers, voltmeter, fuel gauge, 11-03-new question: how to id. the fresh air fan wire ----- (solution: always check and recheck fuses- #9 (4th from right) was off center not in tight |
DRPHIL914 |
Oct 31 2014, 04:19 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Don't know what happened- I also had lost my dash lights earlier, put in a new #7 fuse then o.k. then about 30 minutes later I ooze all that stuff and the center console everything - volt meter oil temp gauge and a/f meter all out- what to check first!
Dave_Darling |
Oct 31 2014, 07:41 PM
It's still a fuse. Remove each fuse and inspect.
--DD |
DRPHIL914 |
Oct 31 2014, 09:55 PM
It's still a fuse. Remove each fuse and inspect. --DD Dave you were correct! When you suggested this I dug out my tech tips book- page 81 #611 : if the alternator light glows and the tach needle drops when applying the brakes this is a loose fuse #9, " So I went back out to check this and it looked normal and in place but the top of the fuse was not in position tight! Once adjusted all is well. SO! I am definitely going to replace this fuse panel this weekend!!!! |
Lo-Fi Version | Time is now: 18th May 2024 - 03:40 AM |
