Help! just lost my tach, wipers, voltmeter, fuel gauge, 11-03-new question: how to id. the fresh air fan wire ----- (solution: always check and recheck fuses- #9 (4th from right) was off center not in tight |
DRPHIL914 |
Oct 31 2014, 04:19 PM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Don't know what happened- I also had lost my dash lights earlier, put in a new #7 fuse then o.k. then about 30 minutes later I ooze all that stuff and the center console everything - volt meter oil temp gauge and a/f meter all out- what to check first!
Dave_Darling |
Oct 31 2014, 07:41 PM
It's still a fuse. Remove each fuse and inspect.
--DD |
DRPHIL914 |
Oct 31 2014, 09:55 PM
It's still a fuse. Remove each fuse and inspect. --DD Dave you were correct! When you suggested this I dug out my tech tips book- page 81 #611 : if the alternator light glows and the tach needle drops when applying the brakes this is a loose fuse #9, " So I went back out to check this and it looked normal and in place but the top of the fuse was not in position tight! Once adjusted all is well. SO! I am definitely going to replace this fuse panel this weekend!!!! |
poorsche914 |
Dec 15 2014, 04:43 PM
T4 Supercharged Group: Members Posts: 3,090 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
... I dug out my tech tips book- page 81 #611 : if the alternator light glows and the tach needle drops when applying the brakes this is a loose fuse #9, " And this is why I love this site... Driving to work this morning, my alt light came on, tach started acting funny and would drop to 0 when brakes were applied, plus other electrical glitches. Drove home after work, did a search, and found my answer in under 5 minutes (IMG:style_emoticons/default/aktion035.gif) Checked fuse #9 and, sure enough, it was bad. The metal piece fell right out! Replaced the fuse and back in business (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/driving.gif) |
DRPHIL914 |
Dec 15 2014, 08:54 PM
... I dug out my tech tips book- page 81 #611 : if the alternator light glows and the tach needle drops when applying the brakes this is a loose fuse #9, " And this is why I love this site... Driving to work this morning, my alt light came on, tach started acting funny and would drop to 0 when brakes were applied, plus other electrical glitches. Drove home after work, did a search, and found my answer in under 5 minutes (IMG:style_emoticons/default/aktion035.gif) Checked fuse #9 and, sure enough, it was bad. The metal piece fell right out! Replaced the fuse and back in business (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/driving.gif) Awesome. After that happened to me I decided to finally replace my board with the new one with blade fuses (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 06:56 AM |
