How to check for vacuum leaks, What are the tips and tricks ? |
913B |
Oct 31 2014, 06:15 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
From the last time I tried with the engine running and spraying carb cleaner everywhere and causing a big mess. I did not really see a big RPM difference, maybe I was doing it wrong, maybe I was expecting too big a change and moved on too quickly, but nothing really came from it. I still suffer from a periodic hi idle (1500 rpm), sometimes it idles fine at 800. If it was a vacuum leak why did it correct itself and sometimes idle at 800 ? I have since removed the AAR and even swapped out the MPS with another one, no difference. Stock 1.7 FI
So the discussion for today is what is the proper method, tips and tricks to perform a good vacuum leak check. I am tempted to make a DIY homemade smoke machine from watching youtube to blow smoke in my FI system and check it that way ?? Thoughts (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
r_towle |
Nov 1 2014, 08:54 AM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Go back to the issue.
A periodic high idle , in my opinion, is not a vacuum leak. I would look at cleaning your distributor advance plates and regreasing them. |
913B |
Nov 1 2014, 11:54 AM
Go back to the issue. A periodic high idle , in my opinion, is not a vacuum leak. I would look at cleaning your distributor advance plates and regreasing them. Yeah I did that too, completely removed and rebuilt the distributor, unless i didnt greased it enough, it did move when I used my mity-vac on it ? (IMG:style_emoticons/default/confused24.gif) Maybe a different sensor then CHT or IAT confusing the ecm ? |
Lo-Fi Version | Time is now: 12th May 2024 - 06:21 PM |
