How to check for vacuum leaks, What are the tips and tricks ? |
913B |
Oct 31 2014, 06:15 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
From the last time I tried with the engine running and spraying carb cleaner everywhere and causing a big mess. I did not really see a big RPM difference, maybe I was doing it wrong, maybe I was expecting too big a change and moved on too quickly, but nothing really came from it. I still suffer from a periodic hi idle (1500 rpm), sometimes it idles fine at 800. If it was a vacuum leak why did it correct itself and sometimes idle at 800 ? I have since removed the AAR and even swapped out the MPS with another one, no difference. Stock 1.7 FI
So the discussion for today is what is the proper method, tips and tricks to perform a good vacuum leak check. I am tempted to make a DIY homemade smoke machine from watching youtube to blow smoke in my FI system and check it that way ?? Thoughts (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
boxsterfan |
Nov 1 2014, 11:16 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
My idle problems went away with a new CHT and spacer. 1974 2.0L.
BeatNavy |
Nov 2 2014, 05:30 AM
My idle problems went away with a new CHT and spacer. 1974 2.0L. I like the spacer, too. It really helped warm-up by preventing engine from going too lean. But I'm not sure this will help stabilize idle, particularly after warm-up. Based on what else you've tried I'd think about the dizzy like Rich suggests. |
Lo-Fi Version | Time is now: 13th May 2024 - 10:13 AM |
