I think it's the carb, Too mush fuel |
RogerYellow914 |
Nov 1 2014, 09:12 PM
Member Group: Members Posts: 72 Joined: 4-December 05 From: Redlands, CA Member No.: 5,230 |
The car was running fine. Then last week, it started to pop and backfire on the freeway at 70 in 5th. It did fine in 4th at 70. Later in the day going up a grade at 70, it started to backfire real bad and lost power. I pulled over and it wouldn't idle. It was hard to start and then died. Investigation found fuel on the air cleaner cover on the passenger side carb.
Is this an indication that this float is bad? Is there a way to test the float vs. the valve? Does this look like too much fuel in the bowl? Thanks, Roger |
RogerYellow914 |
Nov 23 2014, 08:10 PM
Well I rebuilt the carb and put everything back together. It barely started and had the same poor running condition and backfiring.
I thought, maybe I've got an ignition problem. That checked out fine. So, maybe a valve got out of adjustment? Holy crap. All the valves on 3 and 4 were very tight. Adjusted ALL the valves. It started right up. Horrible idle. But, after going through the adjustment process got it to idle smoothly. I only adjusted the passenger side since that was the one I rebuilt. And everything had been working well with them beforehand. Took it out for a test drive. Way down on power. Poor throttle response. After about a mile or two got a backfire. Took it home and put it away. Concerned that while it was running with the valves tight might have done some major damage. How do I check? Any suggestions for what I should do next? Usually, when I adjust the valves there is barely any adjustment needed. What would make it get thight so quickly? |
Lo-Fi Version | Time is now: 13th May 2024 - 11:03 AM |
