I think it's the carb, Too mush fuel |
RogerYellow914 |
Nov 1 2014, 09:12 PM
Member Group: Members Posts: 72 Joined: 4-December 05 From: Redlands, CA Member No.: 5,230 |
The car was running fine. Then last week, it started to pop and backfire on the freeway at 70 in 5th. It did fine in 4th at 70. Later in the day going up a grade at 70, it started to backfire real bad and lost power. I pulled over and it wouldn't idle. It was hard to start and then died. Investigation found fuel on the air cleaner cover on the passenger side carb.
Is this an indication that this float is bad? Is there a way to test the float vs. the valve? Does this look like too much fuel in the bowl? Thanks, Roger |
RogerYellow914 |
Nov 23 2014, 11:54 PM
Thanks for the responses. Hopefully I'll have time next weekend to work on it. I need to find a compression tester and an air compressor. Good excuse to buy more tools.
Lo-Fi Version | Time is now: 13th May 2024 - 02:06 PM |
