I think it's the carb, Too mush fuel |
RogerYellow914 |
Nov 1 2014, 09:12 PM
Member Group: Members Posts: 72 Joined: 4-December 05 From: Redlands, CA Member No.: 5,230 |
The car was running fine. Then last week, it started to pop and backfire on the freeway at 70 in 5th. It did fine in 4th at 70. Later in the day going up a grade at 70, it started to backfire real bad and lost power. I pulled over and it wouldn't idle. It was hard to start and then died. Investigation found fuel on the air cleaner cover on the passenger side carb.
Is this an indication that this float is bad? Is there a way to test the float vs. the valve? Does this look like too much fuel in the bowl? Thanks, Roger |
Mike Bellis |
Jan 3 2015, 10:15 AM
Popping is usually due to lack of fuel. A lean condition could explain the burnt away electrode as well. Your carb may be plugged.
drifter914 |
Jan 3 2015, 10:36 AM
drifter914 Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
Popping is usually due to lack of fuel. A lean condition could explain the burnt away electrode as well. Your carb may be plugged. I had similar problem once, backfiring, running badly & turned out the coil had vibrated in it's bracket & rotated around until it was grounding one of the connections on the sheet metal ! Hope that's it... check your coil... simple fix ! Best wishes... Terry |
Lo-Fi Version | Time is now: 13th May 2024 - 05:49 AM |
