I think it's the carb, Too mush fuel |
RogerYellow914 |
Nov 1 2014, 09:12 PM
Member Group: Members Posts: 72 Joined: 4-December 05 From: Redlands, CA Member No.: 5,230 |
The car was running fine. Then last week, it started to pop and backfire on the freeway at 70 in 5th. It did fine in 4th at 70. Later in the day going up a grade at 70, it started to backfire real bad and lost power. I pulled over and it wouldn't idle. It was hard to start and then died. Investigation found fuel on the air cleaner cover on the passenger side carb.
Is this an indication that this float is bad? Is there a way to test the float vs. the valve? Does this look like too much fuel in the bowl? Thanks, Roger |
Elliot Cannon |
Jan 3 2015, 06:19 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
Make sure the idle jets are clean. This might help setting up the carbs. http://www.carburetion.com/weber/adjust.htm
Ansbacher |
Jan 3 2015, 09:34 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Take Drifter914's advice and check the coil. Even if it checks out good statically, it may be bad when under load. Only way to be sure is to use a known good or new coil in its place. I just went through a similar nightmare and it turned out to be the coil. Since they hardly ever fail, it was the last thing I tried after wasting a lot of time and money.
Lo-Fi Version | Time is now: 12th May 2024 - 09:48 AM |
