Converting a Vanagon TB for use with 1.8 L-Jet, How I did it |
MrKona |
Nov 2 2014, 08:36 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
There's currently a thread about using L-jet from a 1.8L engine for a 2.0 with discussion about using bigger bore throttle body from a later Vanagon.
I tried it but ran into an issue with the orientation of the flat on the shaft that engages the throttle body switch component used with L-Jet. Pictures are worth a thousand words, so here goes.. Here's the TPS and a picture of each TB with the plate in the throttle closed position. Original 1.8 L-jet on the right, Vanagon donor TB on the left. Notice the different orientation of the flat on the shafts. The flat engages a corresponding flat on the TPS. The flat on the Vanagon shaft is in the wrong position for the TPS. Attached image(s) |
MrKona |
Nov 2 2014, 09:34 PM
One more note, you may have noticed already that there is a casting difference between the original TB and Vanagon TB where the TPS attaches. It feels pretty well anchored with one screw and of course the shaft that inserts into the TPS. Just for good measure, I put a zip tie around the non-screwed end and the vacuum port. I doubt it's needed, but it's just added assurance.
Attached image(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 08:13 PM |
