Converting a Vanagon TB for use with 1.8 L-Jet, How I did it |
MrKona |
Nov 2 2014, 08:36 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
There's currently a thread about using L-jet from a 1.8L engine for a 2.0 with discussion about using bigger bore throttle body from a later Vanagon.
I tried it but ran into an issue with the orientation of the flat on the shaft that engages the throttle body switch component used with L-Jet. Pictures are worth a thousand words, so here goes.. Here's the TPS and a picture of each TB with the plate in the throttle closed position. Original 1.8 L-jet on the right, Vanagon donor TB on the left. Notice the different orientation of the flat on the shafts. The flat engages a corresponding flat on the TPS. The flat on the Vanagon shaft is in the wrong position for the TPS. Attached image(s) |
ClayPerrine |
Oct 1 2016, 12:06 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I did this for Betty's car. I don't know if it really helped., but It makes a difference on the "butt dyno".
Easy to do too. Just about an hour to do all the work. And I fixed it so that there are two screws holding the throttle switch assembly to the body. One is inside, and one on the outside. |
jim_hoyland |
Oct 8 2016, 08:46 PM
Get that VIN ? Group: Members Posts: 9,303 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I did this for Betty's car. I don't know if it really helped., but It makes a difference on the "butt dyno". Easy to do too. Just about an hour to do all the work. And I fixed it so that there are two screws holding the throttle switch assembly to the body. One is inside, and one on the outside. Clay, DiD you use the 1.8 TPS on the Vanagon TB ? |
Lo-Fi Version | Time is now: 20th May 2024 - 06:23 PM |
