Converting a Vanagon TB for use with 1.8 L-Jet, How I did it |
MrKona |
Nov 2 2014, 08:36 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
There's currently a thread about using L-jet from a 1.8L engine for a 2.0 with discussion about using bigger bore throttle body from a later Vanagon.
I tried it but ran into an issue with the orientation of the flat on the shaft that engages the throttle body switch component used with L-Jet. Pictures are worth a thousand words, so here goes.. Here's the TPS and a picture of each TB with the plate in the throttle closed position. Original 1.8 L-jet on the right, Vanagon donor TB on the left. Notice the different orientation of the flat on the shafts. The flat engages a corresponding flat on the TPS. The flat on the Vanagon shaft is in the wrong position for the TPS. Attached image(s) |
Porschef |
Nov 17 2016, 11:59 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Jim, what did you find to feel different? How was the idle?
Looks like very nice work. (IMG:style_emoticons/default/beerchug.gif) |
jim_hoyland |
Nov 17 2016, 01:02 PM
Get that VIN ? Group: Members Posts: 9,300 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Jim, what did you find to feel different? How was the idle? Looks like very nice work. (IMG:style_emoticons/default/beerchug.gif) More power! Complements the larger P & C Idle is fine One problem this am: the angle of the TB accelerator arm is another 10 degrees back making it had to acetate smoothly. Going to contact Mr Kona Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 01:55 PM |
