Converting a Vanagon TB for use with 1.8 L-Jet, How I did it |
MrKona |
Nov 2 2014, 08:36 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
There's currently a thread about using L-jet from a 1.8L engine for a 2.0 with discussion about using bigger bore throttle body from a later Vanagon.
I tried it but ran into an issue with the orientation of the flat on the shaft that engages the throttle body switch component used with L-Jet. Pictures are worth a thousand words, so here goes.. Here's the TPS and a picture of each TB with the plate in the throttle closed position. Original 1.8 L-jet on the right, Vanagon donor TB on the left. Notice the different orientation of the flat on the shafts. The flat engages a corresponding flat on the TPS. The flat on the Vanagon shaft is in the wrong position for the TPS. Attached image(s) |
Geezer914 |
Feb 17 2021, 07:23 AM
Geezer914 Group: Members Posts: 1,415 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
The 1.8 plenum is only 45mm. The throttle body is 50mm. I used a tail pipe expander and opened the plenum to 51mm.
Lo-Fi Version | Time is now: 17th May 2024 - 08:38 AM |
