Converting a Vanagon TB for use with 1.8 L-Jet, How I did it |
MrKona |
Nov 2 2014, 08:36 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
There's currently a thread about using L-jet from a 1.8L engine for a 2.0 with discussion about using bigger bore throttle body from a later Vanagon.
I tried it but ran into an issue with the orientation of the flat on the shaft that engages the throttle body switch component used with L-Jet. Pictures are worth a thousand words, so here goes.. Here's the TPS and a picture of each TB with the plate in the throttle closed position. Original 1.8 L-jet on the right, Vanagon donor TB on the left. Notice the different orientation of the flat on the shafts. The flat engages a corresponding flat on the TPS. The flat on the Vanagon shaft is in the wrong position for the TPS. Attached image(s) |
VaccaRabite |
May 2 2021, 06:55 AM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Is the 2.1l TB the one off a wasserboxer?
@mrkona Trying to research quickly to do this mod start to finish and have it done by the end of May. Zach |
ClayPerrine |
May 2 2021, 08:27 AM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Is the 2.1l TB the one off a wasserboxer? @mrkona Trying to research quickly to do this mod start to finish and have it done by the end of May. Zach It is off a 2.1 vanagon. Part #025133067A Here is a link to one with the intake for $75.00 http://www.2040-parts.com/vw-air-distribut...witch--i225831/ |
Lo-Fi Version | Time is now: 17th May 2024 - 01:34 PM |
