| DRPHIL914 |
Nov 5 2014, 07:37 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,955 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
I am installing the new Jwwest fuse box and
I have a 3" section of wire off the #5 back row fuse that has melted insulation(grey with black stripe) what is the best way to replace and splice in the new piece and what gauge wire is correct? |
Philip W. I need to fix and replace some bad wiring(melted) near the fuse box Nov 5 2014, 07:37 AM
bdstone914
I h... Nov 5 2014, 09:38 AM
type47
... to replace and splice in the new piece ...
I... Nov 5 2014, 10:15 AM
Philip W. Circuit board in place with a few new connectors a... Nov 5 2014, 09:21 PM
Philip W.
Circuit board in place with a few new connectors ... Nov 7 2014, 07:24 AM
billh1963
Circuit board in place with a few new connectors ... Nov 7 2014, 08:35 AM
Philip W.
Circuit board in place with a few new connectors... Nov 7 2014, 09:56 AM
Philip W.
Circuit board in place with a few new connectors... Nov 7 2014, 12:53 PM
76-914 12volts at the coil with key on? Do it quickly. Re... Nov 7 2014, 07:53 AM
Philip W.
12volts at the coil with key on? Do it quickly. R... Nov 7 2014, 09:59 AM
Dave_Darling Tape an extra spark plug to a ground, and plug in ... Nov 7 2014, 10:58 AM
Philip W.
Tape an extra spark plug to a ground, and plug in... Nov 7 2014, 12:49 PM
Racer Chris Some of the fuse circuits in the old panel are bri... Nov 7 2014, 11:14 AM
Philip W.
Some of the fuse circuits in the old panel are br... Nov 7 2014, 12:42 PM
Racer Chris
do you know which circuits have this?
:idea:
T... Nov 7 2014, 01:44 PM
Jeff Bowlsby Wait.
It worked before the fuse panel swap, and ... Nov 7 2014, 01:06 PM
Tom You are getting lost in " OMG, what is wrong... Nov 7 2014, 02:45 PM
Philip W. So this morning I took Tom's advice and starte... Nov 8 2014, 10:01 AM
Mike Bellis Glad you got it running.
For the record, the igni... Nov 8 2014, 10:19 AM
Tom Glad I was able to get you to stop and think for a... Nov 8 2014, 02:49 PM
Philip W. Turns out since tje battery was disconnected I nee... Nov 8 2014, 10:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th July 2026 - 06:36 AM |
