LSD for 914, not the drug.... |
Mueller |
Jan 31 2005, 03:15 PM
sounds like you have crappy tires...what you might need is a spare set of winter only tires......... the LSD can help or be hinderance also...sometimes it's safer to only have one drive wheel in the rain or snow depending on the driver skill.... |
IronHillRestorations |
Jan 31 2005, 03:18 PM
I. I. R. C. Group: Members Posts: 6,715 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
To answer the original quesiton, yes, you can put a limited slip in a 914 transmission. I had it done to my own personal car when I did a 3.0 six conversion on it, which was in fact a street car. It will cost you probably between $2500 and $3000 (minimum) to get the parts and the gearbox rebuilt. Last time I had one done for a customer we were into the gearbox for around $3500 total, so if you scrimp on parts a little you may be able to save a little. You can't however, just get a limited slip or torque biasing diff and stick it in the transmission, it's a fairly complicated proceedure and involves setting the pinion depth, which involves special tools ($$$). There are two different kinds of diffs you can get a torque biasing like a Quaife or Guard, or a clutch pack type like the original ZF and Guard makes one of those too. The torque biasing are a little more "snappy" on the track, that is they are either open or locked and sometimes you can feel them lock up which results in the "snappy" feel. The clutch pack types can be set for a range of slippage depending on the clutch pack assembly. If you can find a factory ZF I'd expect to pay between $900-$1500 for a rebuilt unit, perhaps more. The Quaife and Guard torque biasing diffs are usually $1200, maybe a little or less. If I remember right a new Guard clutch pack diff is very expensive, in the $2500 range. Limited slip was an option for 914's. If the gearbox hasn't been rebuilt, there should be a little aluminum tag on one of the upper studs of the side cover (on the passenger side). 914's with factory limited slip are very rare. I hope this answers your question. Sure, an open diff will result in inside wheel spin. But what's that going to hurt on a street car Toby? You aren't going to loose any lap times, or miss any extra cones. Sure if you've got a open budget, get the gonzo diff, but there's probably lots of other things you can do to make the car faster, before you start throwing big money at the transmission. Good grief, I'm sure there's plenty of guys on this board that spent $3000 or less on the 914 they own. There isn't a wealth of 914 owners that are going to shell out 30-100% of the purchase price of the 914 for such an upgrade. I'm not spouting BS here, I'm trying to give good advice. Did I push the wrong button Toby? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Is the baby keeping you up and making you a little cranky? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
bd1308 |
Jan 31 2005, 03:36 PM
Yeah I have *NO* driver skill....i wrecked my precious baby 914 into the back of a Explorer in the snow.....but otherwise I am a very good driver. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) now i have to go to south KY to get a hot pink 914 to fix mine. How embarrasing what winter tires do you all recommend? |
Mueller |
Jan 31 2005, 03:41 PM
I have no idea...I live in sunny California (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
ArtechnikA |
Jan 31 2005, 03:44 PM
there's a few. if you can afford to dedicate them to winter driving, Blizzak's always get good reviews. if you get a lot of ice, and they're legal where you live, studded snows are pretty amazing. |
bd1308 |
Jan 31 2005, 04:01 PM
rigth now, I have a set of falkens....the ZE-502s....supposedly a good tire. Dunno anythign about tires though. The guy was worried they wouldnt fit, at Big O Tires...... (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif)
Air_Cooled_Nut |
Jan 31 2005, 04:35 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
Okay, you prolly got me there, sorry man (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) My assumption was that the tires were good ones. Yes, a tire can make a bunch o' differnece in traction, handling and braking. And yes, the LSD is a chunck o' change but we save our money for something (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
bd1308 |
Jan 31 2005, 04:41 PM
so whats a good tire then? I mean all-season...
Jan 31 2005, 05:39 PM
One thing I forgot to mention is that LSD (either flavor) will make the car slew sideways in loose traction situations, gravel, snow, etc. Both tires trying to hook up without traction will do this.
Most of us shudder to think about driving a 914 in snow and salt, although back in 78/79 when I got my first 914 (and only car) I didn't think twice about it, and it's actually a great car in the snow. I've got a good deal on some Yokohama AVS, pm me if you are interested. |
don9146 |
Jan 31 2005, 07:45 PM
Member Group: Members Posts: 199 Joined: 3-January 04 From: Nashville, TN Member No.: 1,500 Region Association: None |
Phil Wicks ( http://www.wicksdrivingacademy.com/index.htm ) moved to Nashville last year and is putting on his driving school at local tracks (i.e. Nashville Superspeedway, Memphis Motorsports Park, Road Atlanta, Gateway International Raceway, Little Talledega, and possibly Barber Motorsports Park). I plan on taking my six-converterd car to as many events as possible this year. The Tennessee Spokes ( http://www.tennessee-spokes.org/ ) also put on some nice autocrosses and their Road Cross always brings out some nice cars. Not sure whats available in Bowling Green Porsche-wise except "The Visit" to the Corvette Factory that the Nashville region PCA puts on each year. |
Jan 31 2005, 08:52 PM
Custom Member Group: Members Posts: 24,570 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
if you can afford to get a cheap set of steel wheels, put on four snow tires for the winter.
I live in snow country and I cannot find an "all season" tire that is worth its name in the snow... If you get alot of snow, get another set of rims and get a set of snows...the cheap snows at sears work great, just remember that they wear out quickly, so take them off as soon as the snow is gone, march/april and put on your summer tires. Tires have different wear ratings and summer tires are to wide for winter snow driving....you want thin tires that have teeth...your not trying to look good in the snow, you are trying to get there.... Rich |
bd1308 |
Jan 31 2005, 09:04 PM
actually to tell you all the truth, KY doesn't get much snow. we havent had alot of snow (this time) since 1994. They do put down ALOT of salt. I think what i'll do is bum the g/f's car and ride with her when it snows. this past snowfall, I just drove real slow and then i wash the car every couple of days. Underneath, in the wheel wells....(how do you wash in the longitudinals?) and pretty much every where else. I try to get everyone to look underneath structurally everytime it is in the shop (every month or two (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) ) and so far there isnt any cancerous rust to worry about....
root |
Jan 31 2005, 10:16 PM
Two Wheeled Type4 Completed! Group: Members Posts: 849 Joined: 5-May 04 From: Sterling, VA Member No.: 2,026 Region Association: None |
[QUOTE]I try to get everyone to look underneath structurally everytime it is in the shop (every month or two wink.gif ) and so far there isnt any cancerous rust to worry about....
I lived in the Bluegrass State for 10 years. Bought my first new 914 in Lexington in 1974. If your 914's been driven in KY in the winter (KY-slush = salt = rust) and hasn't been rustorated (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) You had better look real close. Limted SLip Diff's are a piece of cake install in a conventional rear weel drive axle. Drain the oil. Pop off the old diff case. Insert the new, w/ Uck'm Pucky Fill with new oil. Done! (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) LSDiff's are a nightmare install on transaxle's. Buy one and replace your's. |
root |
Jan 31 2005, 10:19 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) I just figured out I bunged the quote the first time! (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
ws91420 |
Jan 31 2005, 10:32 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
Michelin Pilot Sports are good I put 195/60/15 on my car good wet dry and rated for snow.
bd1308 |
Jan 31 2005, 10:42 PM
i should just dip the entire car in POR-15....i'm beginning to like the black color anyway (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
DJsRepS |
Feb 4 2005, 07:17 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
My stock 72/1.7 is not LSD but it lays down rubber from both wheels on pavment.
Lo-Fi Version | Time is now: 1st May 2024 - 08:58 PM |
