> Here's a different Oil Cooler Idea
carr914
post Nov 8 2014, 05:13 AM
Racer from Birth
at SEMA
http://www.chevyhardcore.com/features/sema...ce-oil-cooling/
EdwardBlume
post Nov 8 2014, 05:56 AM
I wonder if you could use two of these in tandem?
damesandhotrods
post Nov 8 2014, 05:40 PM
I would imagine that you’d loss some oil cooler efficiency, and it would need have to have clean air flow. I don’t think it’s that revolutionary of an idea, VW and 914 owners have been mounting oil coolers parallel to air flow for decades.
Mike Bellis
post Nov 8 2014, 06:32 PM
Resident Electrician
I thought I was going to be more impressed when I clicked... (IMG:style_emoticons/default/sad.gif)
a few loose screws
post Nov 8 2014, 07:38 PM
All that contraption will do is speed up airflow ever so slightly over part of the cooler, the inlet still needs airflow. I see its intended purpose is to be hidden under the car, tucked up against a frame rail or something. It seems like it was designed to make a poorly located oil cooler function slightly better, as opposed to mounting it in a place that would make it actually work efficiently. A cooler with a scoop, wonder what that will cost.
Mark Henry
post Nov 8 2014, 08:23 PM
that's what I do!
QUOTE(RobW @ Nov 8 2014, 06:56 AM) *
The EMPI batwing cooler (IMG:style_emoticons/default/smile.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-26-1415499803.1.jpg)
- Lo-Fi Version Time is now: 13th March 2026 - 01:24 AM
