| rmital |
Nov 10 2014, 10:07 AM
Northeast optimist ![]() ![]() ![]() Group: Members Posts: 1,955 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
got a box full of them. want to use a good one. not interested in buying a new one "if" I have 5 good ones on my shelf.
thanks..... (IMG:style_emoticons/default/flag.gif) |
| Spoke |
Nov 10 2014, 10:23 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,355 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
I assume you mean ignition coils.
You could measure the resistance from + to -, and + to distributor output. They should all be the same for each measurement. Get a known good coil as the standard. What you won't be able to measure if any are heat sensitive. You could swap them in and out of a engine to check. The coil doesn't have to be mounted to do this; just moving wires. |
| stugray |
Nov 10 2014, 11:12 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I have a setup that is more than you are probably talking about.
I have a spark plug with an adjustable spark gap, a set of points, battery charger that I was using to experiment with Ignition pulse detection. The adjustable gap plug was a few bucks at harbor freight This pic shows it with a standard spark plug: (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1415639539.1.jpg) And a video of a fouled plug. http://vid366.photobucket.com/albums/oo101...zpslne8tn0r.mp4 This is the gap tester: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.mr2.com-10819-1415639730.1.jpg) So to test coils, I would put each in the test rig, and open the plug gap until you get no spark. The plug gap is marked in 1000 volt measurements so you could tell if one coil was putting out a weaker spark than a"known good" coil. The resistance check is better than nothing but you could have hundreds of windings shorted out and not be able to tell with the DC resistance check since the R is so low already (3-5 Ohms). |
| rmital |
Nov 10 2014, 12:05 PM
@spoke, yes ignition coil...edited the title. thanks.
@stugray, holy crap, you people never cease to amaze me. (IMG:style_emoticons/default/flag.gif) I'll see what spoke's test tells me...I'm sure the one in question is good, just curious if there was a basic test. |
| bandjoey |
Nov 10 2014, 02:36 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
There is an old thread on this. If no one finds it I'll get it tonight. On my phone now.
As example (can't remember the exact). Center to + needs to read no less than xx ohms volts something and then. + to - needs to be xx something. You can google testing Bosch coils too and there are VW threads too. Did this a year ago. Will update this whn I find something. Search is a good friend. Try this http://www.thesamba.com/vw/forum/viewtopic.php?t=410728 |
| rmital |
Nov 10 2014, 02:44 PM
.... Will update this whn I find something. Search is a good friend. .... I searched and found a Dave Darling procedure...it read like stereo instructions. (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/wacko.gif) |
| ChrisFoley |
Nov 10 2014, 04:10 PM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Throw it in a pond and if it floats its no good.
| Olympic 914 |
Nov 10 2014, 05:01 PM
![]() ![]() ![]() Group: Members Posts: 1,770 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
I believe a coil can test good with a multimeter and still be bad. But if it tests bad, it is. I recently had an issue with the coil on my old Cub Cadet and it tested good but still would not run right, or it would run a little while then quit. So I took my 914 coil and mounted it on there and it worked.
So I just bought a new coil to put on the car. |
| r_towle |
Nov 10 2014, 05:59 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
| era vulgaris |
Nov 10 2014, 06:43 PM
J is for Genius ![]() ![]() ![]() Group: Members Posts: 986 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
| Tom |
Nov 10 2014, 08:24 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
I believe the DC resistance of the + to - should be in the range of about 3 ohms, the + to center should be 8-12K ohms.
Tom |
| timothy_nd28 |
Nov 10 2014, 08:30 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
| DRPHIL914 |
Nov 10 2014, 09:16 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,892 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
I was just going thru this recently myself and ran across this on pelican.
Measuring from + to neg is .75 ohms to 0.81, and from the center pole to + should be 10,000 ohms to 11,000 ohms. I guess thats one plave to start. |
| r_towle |
Nov 11 2014, 06:59 AM
Throw it in a pond and if it floats its no good. -What also floats in water? -Bread, apples, very small rocks.... -A DUCK! So logically if your ignition coil weighs the same as a duck, then it's no good. (IMG:style_emoticons/default/agree.gif) |
| Tom |
Nov 11 2014, 02:42 PM
Just thought I should throw this out there.
A simple DC resistance test will only test the primary and secondary windings under not running conditions. Coils will and do break down under heat and electrical load. Many folks get really discouraged when testing ignition systems on cars that won't start or run right and when doing the spark plug outside the engine test get a spark. Well there are sparks and there are SPARKS. A strong blue spark is preferred. I remember back in about 1970 taking a gas engine course and during the ignition part the instructor showed us an engine that had what seemed to be a good spark. Would not start! The class went thru the entire electrical troubleshooting procedure to try to get the engine to fire. Finally after trading out the coil for a new one, it fired and ran fine. The old coil was putting out a spark that was slightly weak. I wish I could remember why the weaker coil produced what to us looked like a good spark but would not fire under compression. I am sure he explained it, I just can't remember. (IMG:style_emoticons/default/sad.gif) A few years later while playing with RD-350's, I had Don Vesco's shop port and polish the cylinders/pistons, and machine the head for increased compression. The mechanic that performed the work also told me I would have ignition issues if I did not improve the ignition system. When I asked what to do, he said go to K-mart and buy a $6.00 K-Mart coil and install it and widen the plug gap by 0.010 inches. Well I did what he said and it fired just fine. Boy that bike was fast for it's time!!! Maybe Jake or one of the engine builders could tell us more on why coils break down under higher compression. I have heard of lots of guys that had a great running car only to rebuild it with higher compression pistons and then have issues with the stock ignition system. Tom |
| bdstone914 |
Nov 11 2014, 06:28 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,271 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The Haynes manual tests are pretty simple.
Attached thumbnail(s) |
| stugray |
Nov 11 2014, 08:26 PM
Maybe Jake or one of the engine builders could tell us more on why coils break down under higher compression. I have heard of lots of guys that had a great running car only to rebuild it with higher compression pistons and then have issues with the stock ignition system. Tom Here is why: Voltage breakdown in air (or any gas) is when a voltage potential can arc across a gap. The bigger the gap, or the higher the pressure, the more voltage is required to jump the gap. (disclaimer - numbers are approximate for sake of discussion) The voltage for breakdown in air with 0.7mm gap at 1 ATM pressure (14.7 PSI) is ~3400 Volts An engine with a static CR of 8:1 will compress the air to 8 ATM (~118 PSI) which is ~19,000 Volts An engine with a static CR of 10:1 will compress the air to 10 ATM (~147 PSI) which is ~23,000 Volts So to get a spark to even start in the combustion chamber with the stock compression ratio, you need greater than 20,000 volts. As you increase the CR, you increase the voltage required to start the spark. So if you do not bump up the voltage that the ignition system can deliver, then to get any spark at all with the higher CR, you would need to reduce plug gap. Smaller plug gaps mean less energy delivered per spark, and performance drops off. It gets way more complicated after spark ignition, but you get the point. Regardless of CR, you can increase gap if you have a higher ignition output voltage. This is why the MSD is so popular. It allows a bigger gap. |
| r_towle |
Nov 11 2014, 09:08 PM
It's a duck
Lo-Fi Version | Time is now: 16th March 2026 - 09:38 PM |
