Motor Assembly |
Motor Assembly |
Bulldog9 |
Nov 10 2014, 09:01 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
The time has come to start assembling the motor. I painted the tins over the weekend and, all that is left to paint is the fan assembly. 2 years of strip, clean condition paint......... I am done...
I will be cleaning up the garage over the Holiday and weekend and start assembling the motor this weekend or next week. Its been a long 2 years gathering all this, and is hard to believe it is almost time. I will be checking in and asking for advice on the engine build in this thread as my motor is nearly identical to the 914. I have TWO questions at this point, 1. I seem to have misplaced the new recommended list of engine case and sealants. Does anyone have this? 2. It is time to decide if I will use the Steel backed silverline (made in Mexico) bearings, or the non steel backed Mahle (looks to be Brazil). Yeah, I know there are a million opinions on this, and I plan to go with the steel backed at this point, but figured I'd ask. Appreciate any advice here, is my first Type 4 build. THANKS! |
Dave_Darling |
Nov 11 2014, 12:28 AM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
For a Web cam, stick with Web lifters. I've never thought the idea of a hole in the wear surface of a lifter was that good an idea anyway (the "lube a lobe", as I understand it, has an oil hole on the face of the lifter). You really want to make sure the cam and lifters are compatible with each other.
--DD |
Lo-Fi Version | Time is now: 12th May 2024 - 02:39 AM |
