Motor Assembly |
Motor Assembly |
Bulldog9 |
Nov 10 2014, 09:01 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
The time has come to start assembling the motor. I painted the tins over the weekend and, all that is left to paint is the fan assembly. 2 years of strip, clean condition paint......... I am done...
I will be cleaning up the garage over the Holiday and weekend and start assembling the motor this weekend or next week. Its been a long 2 years gathering all this, and is hard to believe it is almost time. I will be checking in and asking for advice on the engine build in this thread as my motor is nearly identical to the 914. I have TWO questions at this point, 1. I seem to have misplaced the new recommended list of engine case and sealants. Does anyone have this? 2. It is time to decide if I will use the Steel backed silverline (made in Mexico) bearings, or the non steel backed Mahle (looks to be Brazil). Yeah, I know there are a million opinions on this, and I plan to go with the steel backed at this point, but figured I'd ask. Appreciate any advice here, is my first Type 4 build. THANKS! |
Bulldog9 |
Dec 13 2014, 09:57 PM
I assembled the short block today (more details in #770 thread)
I went through the Reinz kit and have a few questions Picture 1 is the drain plug, not sure which of the silver gaskets go with it. The one in the center is thick and solid, the one on the right is softer. I doubt the copper goes with it. Where do the other two go? Picture 2 is a collection of two medium o rings, and a thin black. NO idea where they go. My guess on the small is for the distributor shaft, but no idea on the larger one. The remaining pics show what gaskets I matched with what. 3 Is flywheel o ring 4 is the large pressure relief piston |
ChrisFoley |
Dec 14 2014, 09:37 AM
I am Tangerine Racing Group: Members Posts: 7,924 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
... Picture 1 is the drain plug, not sure which of the silver gaskets go with it. The one in the center is thick and solid, the one on the right is softer. I doubt the copper goes with it. Where do the other two go? ... The hollow aluminum one, center bottom, is for the drain plug. The flat aluminum one might go on the oil temp sender. |
Lo-Fi Version | Time is now: 12th May 2024 - 04:11 AM |
