Motor Assembly |
Motor Assembly |
Bulldog9 |
Nov 10 2014, 09:01 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
The time has come to start assembling the motor. I painted the tins over the weekend and, all that is left to paint is the fan assembly. 2 years of strip, clean condition paint......... I am done...
I will be cleaning up the garage over the Holiday and weekend and start assembling the motor this weekend or next week. Its been a long 2 years gathering all this, and is hard to believe it is almost time. I will be checking in and asking for advice on the engine build in this thread as my motor is nearly identical to the 914. I have TWO questions at this point, 1. I seem to have misplaced the new recommended list of engine case and sealants. Does anyone have this? 2. It is time to decide if I will use the Steel backed silverline (made in Mexico) bearings, or the non steel backed Mahle (looks to be Brazil). Yeah, I know there are a million opinions on this, and I plan to go with the steel backed at this point, but figured I'd ask. Appreciate any advice here, is my first Type 4 build. THANKS! |
pilothyer |
Dec 14 2014, 10:37 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Steve......These may be helpful to you. First the picture next the legend.
A Valve Cover Gasket (2) CORK B Exhaust Gasket Ring (4) COPPER C Oil Breather Gasket (1) CORK D Sump cover O-ring (1) RED RUBBER 77 X 4 mm E Muffler Flange Gasket (2) Metalic / Fiber F Flywheel O-ring (1) Graphite Impregnated G Push rod tube inner (8) Black Rubber H Push rod tube outer (8) Green Rubber I Oil Filter Mount (1) Paper J Oil Filler Tube Gasket (1) Paper K Fuel Pump Gasket (1) Paper L Fan Hub O-Ring (1) Rubber M Oil Strainer Crush Washer (2) Aluminum N Oil Plug Crush Washer (1) Copper 14 mm O Distributor O-Ring (1) Black Rubber P Oil Pickup Tube O-ring (1) Black Rubber 13.5 X 2.5 mm Q Oil Cooler Seals (2) Orange/Red Silicone R Oil Pump O-Ring (1) Black Rubber 60.8 X 2 mm S Oil Pickup Case thru Bolt Washer (1) Copper 8.2 X 16 mm T Oil Sump Crush Washer (2) Copper A6 X10 mm U Oil Pressur Control Crush Washer (1) Copper 16 mm V Oil Press Relief Valve Crush Washer (1) Aluminum 22 mm W FLYWHEEL CRUSH WASHER (1) 5 HOLE Metal X Oil Pump Gasket (1) Paper Y OIL Strainer Gaskets (2) Paper -Pair w Alum Crush Z Cylinder Base Gaskets (4) Metal 100 X 109 mm AA Cylinder Head Gaskets (4) Metal 94 X 105 X 0.7 mm 2.0 L BB Cylinder Head Gaskets(4)Metal 93 X 104 X 0.7 mm 1.7,1.8L CC, DD Not Applicable to F.I. EE INTAKE MANIFOLD GASKETS (2) BAKELITE FF CASE VIBRATION DAMPERS (6) NYLON |
Bulldog9 |
Dec 14 2014, 10:56 AM
Lo-Fi Version | Time is now: 12th May 2024 - 04:21 AM |
