Motor Assembly |
Motor Assembly |
Bulldog9 |
Nov 10 2014, 09:01 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
The time has come to start assembling the motor. I painted the tins over the weekend and, all that is left to paint is the fan assembly. 2 years of strip, clean condition paint......... I am done...
I will be cleaning up the garage over the Holiday and weekend and start assembling the motor this weekend or next week. Its been a long 2 years gathering all this, and is hard to believe it is almost time. I will be checking in and asking for advice on the engine build in this thread as my motor is nearly identical to the 914. I have TWO questions at this point, 1. I seem to have misplaced the new recommended list of engine case and sealants. Does anyone have this? 2. It is time to decide if I will use the Steel backed silverline (made in Mexico) bearings, or the non steel backed Mahle (looks to be Brazil). Yeah, I know there are a million opinions on this, and I plan to go with the steel backed at this point, but figured I'd ask. Appreciate any advice here, is my first Type 4 build. THANKS! |
Bulldog9 |
Dec 13 2014, 09:57 PM
I assembled the short block today (more details in #770 thread)
I went through the Reinz kit and have a few questions Picture 1 is the drain plug, not sure which of the silver gaskets go with it. The one in the center is thick and solid, the one on the right is softer. I doubt the copper goes with it. Where do the other two go? Picture 2 is a collection of two medium o rings, and a thin black. NO idea where they go. My guess on the small is for the distributor shaft, but no idea on the larger one. The remaining pics show what gaskets I matched with what. 3 Is flywheel o ring 4 is the large pressure relief piston |
ChrisFoley |
Dec 14 2014, 09:30 AM
I am Tangerine Racing Group: Members Posts: 7,924 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Bulldog9 |
Dec 14 2014, 10:55 AM
Thanks Chris, I figured one of them was for the distributor. I already replaced the o ring on the oil pickup tube.
Still not sure what the large black/thin o ring is for. I assumed the hollow gasket was for the drain plug as the one I pulled off the plug on dissasembly was soft alum. Top left is for the oil pickup tube inside the crankcase. Lower left is for the distributor. |
stugray |
Dec 14 2014, 11:16 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Still not sure what the large black/thin o ring is for. 18 in pic: (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1418577377.1.png) |
Lo-Fi Version | Time is now: 12th May 2024 - 03:40 AM |
