Motor Assembly |
Motor Assembly |
Bulldog9 |
Nov 10 2014, 09:01 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
The time has come to start assembling the motor. I painted the tins over the weekend and, all that is left to paint is the fan assembly. 2 years of strip, clean condition paint......... I am done...
I will be cleaning up the garage over the Holiday and weekend and start assembling the motor this weekend or next week. Its been a long 2 years gathering all this, and is hard to believe it is almost time. I will be checking in and asking for advice on the engine build in this thread as my motor is nearly identical to the 914. I have TWO questions at this point, 1. I seem to have misplaced the new recommended list of engine case and sealants. Does anyone have this? 2. It is time to decide if I will use the Steel backed silverline (made in Mexico) bearings, or the non steel backed Mahle (looks to be Brazil). Yeah, I know there are a million opinions on this, and I plan to go with the steel backed at this point, but figured I'd ask. Appreciate any advice here, is my first Type 4 build. THANKS! |
Bulldog9 |
Dec 14 2014, 01:42 PM
I think I already located the fly wheel O ring,is thicker and dark gray. This is thinner, a bit larger. I set the flywheel O ring with the locking plate in pic 3. The O ring I am still looking to identify is black in the pic with the two smaller black o rings (distributor and chimney o rings).
I was able to identify the other small black o ring, it is for the breather chimney. I also looked at my sensors, and all came with the gaskets so the only one left to identify is the large thin black. Thanks for the help guys. Couldn't do this without your help. Attached image(s) |
Lo-Fi Version | Time is now: 11th May 2024 - 10:44 AM |
