Motor Assembly |
Motor Assembly |
Bulldog9 |
Nov 10 2014, 09:01 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
The time has come to start assembling the motor. I painted the tins over the weekend and, all that is left to paint is the fan assembly. 2 years of strip, clean condition paint......... I am done...
I will be cleaning up the garage over the Holiday and weekend and start assembling the motor this weekend or next week. Its been a long 2 years gathering all this, and is hard to believe it is almost time. I will be checking in and asking for advice on the engine build in this thread as my motor is nearly identical to the 914. I have TWO questions at this point, 1. I seem to have misplaced the new recommended list of engine case and sealants. Does anyone have this? 2. It is time to decide if I will use the Steel backed silverline (made in Mexico) bearings, or the non steel backed Mahle (looks to be Brazil). Yeah, I know there are a million opinions on this, and I plan to go with the steel backed at this point, but figured I'd ask. Appreciate any advice here, is my first Type 4 build. THANKS! |
stugray |
Dec 19 2014, 05:39 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
There should be a mark on the FW that you use as true TDC #1.
The one on the fan is the 27 deg BTDC used for timing at 3500 RPM (for FI). With my carbs I use closer to 34 degrees. And did you measure the cam lobes before installing the cam? |
Lo-Fi Version | Time is now: 11th May 2024 - 09:21 PM |
