In Over My Head Restoration, No More Excuses - Just Start Cutting... |
BeatNavy |
Nov 11 2014, 07:27 PM
Ok, here goes. I picked up this '75 last April in lower Maryland. It was advertised as a 2.0, it has a 2.0 badge on the back, and it looked pretty good from a distance (or with beer goggles).
Attached thumbnail(s) |
altitude411 |
Feb 9 2015, 08:18 AM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
Nice work. What are your thoughts on the (blair) spot weld cutter?
BeatNavy |
Feb 9 2015, 08:25 AM
Nice work. What are your thoughts on the (blair) spot weld cutter? My thoughts are that it's probably more effective than the HF cheapo but that I'm still probably not using it right. I think I went through four bits just to get this console out. The teeth kept breaking on it, probably when I would go in at a different angle than the cut I started with. I did realize you need to use it at very low speed. I also used that stick lubricant, and it catches all the metal shavings which need to be wiped away frequently. I'm not sure any cutter would work magic on this console piece, due to the metal thickness and the weird angles. Hopefully it'll work better for me on the floor plan welds... EDIT: picture added: |
Lo-Fi Version | Time is now: 16th May 2024 - 11:33 PM |
