| DRPHIL914 |
Nov 11 2014, 11:14 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
They are identical and have same numbers but this spare I bought that had been taken apart cleaned by a world member looks like brand new. BUT the rotor is aligned 180 degrees off for the other one when installed? Can this be changed?
If so , how? |
| bdstone914 |
Nov 11 2014, 11:33 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,430 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Remove the part at the bottom of the shaft and rotate it 180.
Remove the spiral spring. Clamp the two nubs in a vice. Drive the pin out. Rotate the shaft 180. Reassemble. |
| dknechtly |
Nov 12 2014, 11:22 AM
Yellow 914 ![]() ![]() Group: Members Posts: 71 Joined: 11-April 03 From: Wylie, TX Member No.: 560 Region Association: None |
Hmmm... don't you just need to take the dist out, rotate it 180 and put it back in?
| Cap'n Krusty |
Nov 12 2014, 12:23 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
No clearance for the vacuum capsule. Do it right, do it once.
The Cap'n |
| dknechtly |
Nov 13 2014, 08:26 AM
I went home last and double checked the bottom of the distributor and the top of the drive... sure enough, the tabs are slightly off center (so it only goes in one way). I always thought it could go in either way! Always something new with these 914's.
Lo-Fi Version | Time is now: 25th November 2026 - 04:01 PM |
