| bluhun |
Nov 13 2014, 10:00 PM
Member ![]() ![]() Group: Members Posts: 91 Joined: 23-January 06 From: San Rafael, CA Member No.: 5,464 Region Association: Northern California |
I purchased a set of the Hayward and Scott heat exchangers for my 1975 3.2 liter conversion several months ago. The conversion was performed 5 years ago and designed around the Billy Boat heat exchangers and muffler system. I was not happy with the B&B system because of the inadequate flow of hot air it delivered, and decided to give the H&S system a try. Attached is a picture of the H&S heat exchangers.
Unfortunately, and not surprisingly, we encountered significant fitment issues with the H&S heat exchangers. First of all, the exhaust primaries would not bolt up with the cylinder heads without enlarging the bolt holes on the exhaust flanges. Not a big issue, just enlarge the holes. The hot-air exit tube on the exchangers needs to be extended by several inches to bolt up to the heater-control valves. The collector end of the exhaust would not mate up with the B&B muffler, necessitating the purchase of a standard 911 banana-type muffler. The most significant fitment issue, however, is that the system interferes with oil changes and exhaust-valve adjustments, requiring the exhaust to be removed in order to do an oil change or an engine service. We reluctantly decided to retain the B&B system for the car, and new heater-control valves did significantly improve the hot-air flow. All-in-all, this has been a very expensive lesson. The H&S exchangers come with 1-3/4" primaries and a 2" collector. The driver's-side comes with an O2-sensor bung installed. I am willing to sell them for considerably less than I paid for them ($2,900 including shipping). I will be posting an ad in the classified section. Attached thumbnail(s) |
bluhun Hayward and Scott 914-6 Heat Exchangers Nov 13 2014, 10:00 PM
r_towle I know a guy who may want those...will point him a... Nov 13 2014, 10:18 PM
rick 918-S Is there a reason aftermarket HE never seem to be ... Nov 13 2014, 10:36 PM
PanelBilly We need to get these made by the 914Rubber team... Nov 13 2014, 10:40 PM
Mark Henry I was expecting better quality than that. :(
Tho... Nov 13 2014, 10:43 PM
bigkensteele
Th... Nov 14 2014, 08:09 PM
campbellcj It's a bummer that SSI, M&K, Dansk or some... Nov 13 2014, 11:05 PM
Cairo94507 I am so sorry to hear that! I had identified ... Nov 13 2014, 11:06 PM
I am so sorry to hear that! I had identified... Nov 14 2014, 07:07 AM
scotty b
I am so sorry to hear that! I had identifie... Nov 14 2014, 07:20 AM
9146986 Bending SS tubing is the big issue, and that's... Nov 14 2014, 08:16 AM
scotty b
Bending SS tubing is the big issue, and that... Nov 14 2014, 09:30 AM
sixnotfour Even made from mild steel with a ceramic coating t... Nov 14 2014, 09:46 AM
r_towle A combined effort between a good tubing shop and s... Nov 14 2014, 09:47 AM
fixer34
A combined effort between a good tubing shop and ... Nov 14 2014, 10:41 AM
rgalla9146
A combined effort between a good tubing shop and... Nov 14 2014, 03:22 PM
SLITS There is also the backside of the cam method. Nov 14 2014, 03:53 PM
GeorgeRud Or simply adjust all the exhausts while under the ... Nov 14 2014, 05:47 PM
wndsnd :popcorn:
Maybe Chris could put a box around his... Nov 14 2014, 07:52 PM
wndsnd What is the process for lowering the engine for va... Nov 14 2014, 08:10 PM
r_towle
What is the process for lowering the engine for v... Nov 14 2014, 09:29 PM
rick 918-S
What is the process for lowering the engine for ... Nov 14 2014, 09:43 PM
wndsnd Well congratulations
Now it is confirmed. You ar... Nov 14 2014, 09:52 PM
Johny Blackstain Well, I find this thread most unsettling <_... Nov 14 2014, 10:15 PM
patssle If MSDS or Tangerine can make headers that get sol... Nov 14 2014, 11:01 PM
9146986 A faulty weld on a header won't kill you.
S... Nov 15 2014, 08:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 11:15 AM |
