Head gasket, Is this the VW bulletin? |
DavidSweden |
Nov 19 2014, 01:51 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am currently rebuilding engine. In order not to tire everyone with a lot of newbie questions I have been searching the forum (thanks for the tip CapĀ“n).
There has been a lot of debate about using or not using head gaskets. Is this the VW tech bulletin which has been referred to in some of the post recommending not to use the head gaskets? VW Tech bulletin head gasket David |
r_towle |
Nov 19 2014, 02:03 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
that is the basic explaination.
I would suggest you assemble the motor dry and measure your deck height (top of piston to top of cylinder) to determine your compression ratio first. then you can use a combination of a head gasket (if you chose) and a cylinder base shim to set your CR properly. Those measurements stated in the bulletin may not even be close to what you really need. |
Lo-Fi Version | Time is now: 11th May 2024 - 08:53 PM |
