Head gasket, Is this the VW bulletin? |
DavidSweden |
Nov 19 2014, 01:51 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am currently rebuilding engine. In order not to tire everyone with a lot of newbie questions I have been searching the forum (thanks for the tip CapĀ“n).
There has been a lot of debate about using or not using head gaskets. Is this the VW tech bulletin which has been referred to in some of the post recommending not to use the head gaskets? VW Tech bulletin head gasket David |
Mark Henry |
Nov 20 2014, 08:15 AM
I haven't built a engine with head gaskets in at least 15 years, I've only ever had one engine failure and it was the last head gasket I used. Blow torched right through it.
Even Porsche eliminated head gaskets on the 3.2, but I guess that's OK because the factory did it. (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 11th May 2024 - 09:53 PM |
