Head gasket, Is this the VW bulletin? |
DavidSweden |
Nov 19 2014, 01:51 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am currently rebuilding engine. In order not to tire everyone with a lot of newbie questions I have been searching the forum (thanks for the tip CapĀ“n).
There has been a lot of debate about using or not using head gaskets. Is this the VW tech bulletin which has been referred to in some of the post recommending not to use the head gaskets? VW Tech bulletin head gasket David |
Mark Henry |
Nov 20 2014, 08:15 AM
I haven't built a engine with head gaskets in at least 15 years, I've only ever had one engine failure and it was the last head gasket I used. Blow torched right through it.
Even Porsche eliminated head gaskets on the 3.2, but I guess that's OK because the factory did it. (IMG:style_emoticons/default/rolleyes.gif) |
r_towle |
Nov 20 2014, 09:23 AM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I haven't built a engine with head gaskets in at least 15 years, I've only ever had one engine failure and it was the last head gasket I used. Blow torched right through it. Even Porsche eliminated head gaskets on the 3.2, but I guess that's OK because the factory did it. (IMG:style_emoticons/default/rolleyes.gif) worked well on the 3.6....which they ended up putting the head gasket back in under a TSB after a few years of problems. On a type 4, I do not run them. I also dont plan to see 100k miles on any of my type 4 motors before I die... I am far to ADHD to wait that long, so I change the motor around anyways every once in a while. My latest rebuild lasted (in my head) about 1 hour...now I MUST change the camshaft not due to any breakage, I just chose the wrong camshaft for my goals. I would not use one, Like Jake said, its one less variable that you have to worry about. Rich |
Lo-Fi Version | Time is now: 11th May 2024 - 11:29 AM |
