Head gasket, Is this the VW bulletin? |
DavidSweden |
Nov 19 2014, 01:51 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am currently rebuilding engine. In order not to tire everyone with a lot of newbie questions I have been searching the forum (thanks for the tip CapĀ“n).
There has been a lot of debate about using or not using head gaskets. Is this the VW tech bulletin which has been referred to in some of the post recommending not to use the head gaskets? VW Tech bulletin head gasket David |
Highland |
Nov 20 2014, 09:56 AM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
When I worked on my motor I searched all the threads on head gasket usage and noticed people only talk about head gasket failure.
For those of you in favor of using the head gasket, what's the failure when no head gasket is used? Has anyone experienced a head seal or overheat issue because of no head gasket? |
Lo-Fi Version | Time is now: 11th May 2024 - 03:06 AM |
