Head gasket, Is this the VW bulletin? |
DavidSweden |
Nov 19 2014, 01:51 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am currently rebuilding engine. In order not to tire everyone with a lot of newbie questions I have been searching the forum (thanks for the tip CapĀ“n).
There has been a lot of debate about using or not using head gaskets. Is this the VW tech bulletin which has been referred to in some of the post recommending not to use the head gaskets? VW Tech bulletin head gasket David |
DBCooper |
Nov 20 2014, 10:19 AM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
The Porsche six cylinder engines aren't really comparable. First because they have individual heads, so get more uniform clamping, and they have aluminum cylinders between aluminum heads and case, all similar metals. The cast iron cylinders in the VW T4 motors are the real problem because they react differently in the heat expansion/contraction cycles than the aluminum heads and case.
Lo-Fi Version | Time is now: 11th May 2024 - 07:50 AM |
