Head gasket, Is this the VW bulletin? |
DavidSweden |
Nov 19 2014, 01:51 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am currently rebuilding engine. In order not to tire everyone with a lot of newbie questions I have been searching the forum (thanks for the tip CapĀ“n).
There has been a lot of debate about using or not using head gaskets. Is this the VW tech bulletin which has been referred to in some of the post recommending not to use the head gaskets? VW Tech bulletin head gasket David |
Elliot Cannon |
Nov 19 2014, 07:20 PM
FAT Performance uses head gaskets. European Motorworks uses head gaskets. As it turns out, so do I. (IMG:style_emoticons/default/biggrin.gif)
r_towle |
Nov 19 2014, 07:56 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
FAT Performance uses head gaskets. European Motorworks uses head gaskets. As it turns out, so do I. (IMG:style_emoticons/default/biggrin.gif) You use lots of things that maybe only you would use (IMG:style_emoticons/default/biggrin.gif) A three letter acronym of a certain substance that smears all over the place..... Things like that .... |
Elliot Cannon |
Nov 20 2014, 12:38 PM
FAT Performance uses head gaskets. European Motorworks uses head gaskets. As it turns out, so do I. (IMG:style_emoticons/default/biggrin.gif) You use lots of things that maybe only you would use (IMG:style_emoticons/default/biggrin.gif) A three letter acronym of a certain substance that smears all over the place..... Things like that .... RTV is NOT an acronym. (IMG:style_emoticons/default/poke.gif) FAT Performance uses it, European Motorworks uses it and as it turns out, so do I. (IMG:style_emoticons/default/av-943.gif) |
brp986s |
Nov 20 2014, 02:36 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
RTV = room temperature vulcanizing - (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/poke.gif)
Lo-Fi Version | Time is now: 11th May 2024 - 02:59 AM |
