Head gasket, Is this the VW bulletin? |
DavidSweden |
Nov 19 2014, 01:51 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am currently rebuilding engine. In order not to tire everyone with a lot of newbie questions I have been searching the forum (thanks for the tip CapĀ“n).
There has been a lot of debate about using or not using head gaskets. Is this the VW tech bulletin which has been referred to in some of the post recommending not to use the head gaskets? VW Tech bulletin head gasket David |
Cap'n Krusty |
Nov 23 2014, 05:02 PM
The point that everyone here seems to have missed is VW redesigned the cylinder heads. The Spanish heads are of the redesigned variety. When that happened, the head gaskets were no longer necessary. They DO NOT tell you to leave out the head gaskets on engines not of the specified series. Note, too, that the 914 2.0 is a VW "BASED" engine, and the pistons, cylinders, and heads are different from the 2.0 VW engine.
The Cap'n |
Lo-Fi Version | Time is now: 11th May 2024 - 07:31 PM |
