Head gasket, Is this the VW bulletin? |
DavidSweden |
Nov 19 2014, 01:51 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am currently rebuilding engine. In order not to tire everyone with a lot of newbie questions I have been searching the forum (thanks for the tip CapĀ“n).
There has been a lot of debate about using or not using head gaskets. Is this the VW tech bulletin which has been referred to in some of the post recommending not to use the head gaskets? VW Tech bulletin head gasket David |
colingreene |
Nov 23 2014, 05:06 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
Of course this whole argument is moot if using 96mm P&C's. QUOTE European told me not to use head gaskets. idk man. I would expect that, did you by chance buy 96mm from them? (IMG:style_emoticons/default/idea.gif) Yes i did, Maybe thats the key? Maybe my reading comprehension is sucking. who knows. I am somewhat new to this. I did notice when i flooded the motor with fuel and got under it, fuel did leak out of the motor from between the barrel and head. (IMG:style_emoticons/default/WTF.gif) however I was told by a aircooled mechanic thats not uncommon since fuel is thin? Runs perfect when started and driven. no leaks that ive noticed. |
Lo-Fi Version | Time is now: 11th May 2024 - 12:20 AM |
