Speaking of Trans Problems |
HarveyH |
Nov 23 2014, 03:54 PM
Member Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 |
I had the car out today and heard a metallic ringing at about 2500 - 3500 RPM, 1st, 2nd and 3rd gears. Not noticeable at higher RPM or higher gears possibly due to road, carb and exhaust noise. Noise also goes away if you feather the throttle or press in the clutch. Trans is full of grease and grease is less than 3000 miles old.
Any ideas? Thanks, Harvey |
wndsrfr |
Nov 25 2014, 08:06 PM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
I had the car out today and heard a metallic ringing at about 2500 - 3500 RPM, 1st, 2nd and 3rd gears. Not noticeable at higher RPM or higher gears possibly due to road, carb and exhaust noise. Noise also goes away if you feather the throttle or press in the clutch. Trans is full of grease and grease is less than 3000 miles old. Any ideas? Thanks, Harvey Trying to visualize what could do this....narrow rpm range & only certain gears....maybe something jangling around in the shifter console?? Maybe clutch throwout fork. Try resting your hand on gearshift lever & pushing it side to side in the 2500-3500 range to see if the noise changes to either point to or eliminate the shift linkage... |
Lo-Fi Version | Time is now: 16th May 2024 - 01:07 PM |
