I need help guys! |
I need help guys! |
porsche-tom |
Nov 25 2014, 02:06 PM
Member Group: Members Posts: 140 Joined: 7-March 13 From: jensen beach fl Member No.: 15,626 Region Association: None |
so i posted before about my about replacing my fuel pump because whenever its hot out it just stops. i cleaned out the gas tank, replaced the fuel lines and replaced the pump with a rotary fuel pump previously recommended. while on the ramps it started fine. i drove it out of the garage and one block away it died again (its about 85 degrees out). it now will not start but i can hear the pump kicking on when ever i turn the key. i am going to wait until tonight when its cooler out and see if it changes but im getting pretty frustrated (IMG:style_emoticons/default/headbang.gif) . does anybody have any ideas?.....please
1972 1.7 carb convert |
jvmarino |
Nov 25 2014, 03:00 PM
Member Group: Members Posts: 81 Joined: 22-March 09 From: Baltimore Member No.: 10,188 Region Association: None |
You may also want to check the fuses on the relay board in the engine compartment. There are 2 bullet style fuses that may have intermittent connections depending on the temperature in the engine bay. If so, you need to clean the contacts and bend them closed more to make a tighter contact. Ask me how I know........
Jim |
Lo-Fi Version | Time is now: 17th May 2024 - 02:08 PM |
