I need help guys! |
I need help guys! |
porsche-tom |
Nov 25 2014, 02:06 PM
Member Group: Members Posts: 140 Joined: 7-March 13 From: jensen beach fl Member No.: 15,626 Region Association: None |
so i posted before about my about replacing my fuel pump because whenever its hot out it just stops. i cleaned out the gas tank, replaced the fuel lines and replaced the pump with a rotary fuel pump previously recommended. while on the ramps it started fine. i drove it out of the garage and one block away it died again (its about 85 degrees out). it now will not start but i can hear the pump kicking on when ever i turn the key. i am going to wait until tonight when its cooler out and see if it changes but im getting pretty frustrated (IMG:style_emoticons/default/headbang.gif) . does anybody have any ideas?.....please
1972 1.7 carb convert |
stugray |
Nov 25 2014, 05:21 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
If the tank vents are clogged, it can pull a vacuum on the tank and stop flow.
when it does it again, take the gas cap off and see if it behaves differently. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:59 PM |
