I need some testing help, Free Parts! |
McMark |
Nov 25 2014, 07:32 PM
While playing with my MicroSquirt kits I found that the stock CHT has a quite frequent failure rate. I used a stock unit on the motor I installed and on my trip to Portland I realized it was giving lots of erroneous readings. When I got back I installed another one, and it was fine for awhile, but eventually started giving the same erroneous readings. I found a modern electronic component which replicates the stock resistance/temp curve of the CHT sensor and isn't prone to vibration/heat damage like the stock unit (including new replacements). I would like to find someone who drives their car enough to notice if there is a difference.
Who's got stock D-Jet installed on their system, drives somewhat regularly and is willing to do some testing? (IMG:style_emoticons/default/beerchug.gif) |
914werke |
Nov 26 2014, 11:57 AM
"I got blisters on me fingers" Group: Members Posts: 10,052 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Mark can you elaborate?
Were these variances something you noticed looking at a map or glitches in drivability that led you to the CHT & observe issues with their resistance/temp curve? |
McMark |
Nov 26 2014, 03:51 PM
Mark can you elaborate? Were these variances something you noticed looking at a map or glitches in drivability that led you to the CHT & observe issues with their resistance/temp curve? Since I'm running MicroSquirt I can graph the readings. I was getting a bit of bucking, each time the reading jumped it would squirt a bunch of fuel. The first one stopped reading all together and just had high resistance, so the engine always thought it was cold. Thankfully I had my laptop with me so I just turned off the cold-start enrichment and ignored the sensor. The second failure was similar, but never got to the worst case scenario. It would buck occasionally - just a quick miss and then back to normal. |
Lo-Fi Version | Time is now: 9th May 2024 - 02:47 PM |
