I need some testing help, Free Parts! |
McMark |
Nov 25 2014, 07:32 PM
While playing with my MicroSquirt kits I found that the stock CHT has a quite frequent failure rate. I used a stock unit on the motor I installed and on my trip to Portland I realized it was giving lots of erroneous readings. When I got back I installed another one, and it was fine for awhile, but eventually started giving the same erroneous readings. I found a modern electronic component which replicates the stock resistance/temp curve of the CHT sensor and isn't prone to vibration/heat damage like the stock unit (including new replacements). I would like to find someone who drives their car enough to notice if there is a difference.
Who's got stock D-Jet installed on their system, drives somewhat regularly and is willing to do some testing? (IMG:style_emoticons/default/beerchug.gif) |
Chris Pincetich |
Nov 27 2014, 10:22 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
WHAT?!?!? You mean chasing the TPS and vacuum leaks isn't the only thing that might be causing my D-jet to experience the mysterious buck n hesitate during the normal driving commute? (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/biggrin.gif)
Very interested in seeing the outcome here. Been upgrading bits in the engine bay to help make my 914 a more reliable commuter (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 10th May 2024 - 08:25 AM |
