I need some testing help, Free Parts! |
McMark |
Nov 25 2014, 07:32 PM
While playing with my MicroSquirt kits I found that the stock CHT has a quite frequent failure rate. I used a stock unit on the motor I installed and on my trip to Portland I realized it was giving lots of erroneous readings. When I got back I installed another one, and it was fine for awhile, but eventually started giving the same erroneous readings. I found a modern electronic component which replicates the stock resistance/temp curve of the CHT sensor and isn't prone to vibration/heat damage like the stock unit (including new replacements). I would like to find someone who drives their car enough to notice if there is a difference.
Who's got stock D-Jet installed on their system, drives somewhat regularly and is willing to do some testing? (IMG:style_emoticons/default/beerchug.gif) |
Jake Raby |
Nov 27 2014, 11:24 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Something else I noted with the stock CHT is the resolution is very notchy.. It may be unresponsive for 20-40 degrees of engine temperature differential, then all of a sudden it'll change. This makes it very difficult to build a MAP of engine temp values in regard to enrichment.
Lo-Fi Version | Time is now: 9th May 2024 - 06:05 PM |
