> Should I get new carbs on my /6 2.2l 911e motor?
tornik550
post Nov 27 2014, 01:55 PM
I recently purchased a 911e 2.2l engine. Befor I install it in my 914, should I change carbs? A previous owner at some point changed from MFI to zenith 40 tin carbs. From my understanding, this is probably not the best setup for a 911e 2.2? I have looked at the different options, which do you think is most appropriate taking cost, hp/torque gains, drivability...
1. Leave the zenith carbs
Pros- I already have them
Cons- probably better forming options
2. Change back to MFI
I probably can't do this one. I have no where to obtain the setup and I really am more comfortable with carbs
3. Change to weber 40 Ida's
Pros- ? Power?
Cons- expensive. Most likely between $2000-$2500 after rebuild
4. PMO carbs
Pros- improved overall performance compared with the zeniths. Easy setup. Is it worth the cost?
Cons- very expensive-$3600.
Here are some other things that I am doing to the engine other than basic maintenance. Pertronix for the distributor, new plug wires (clewett), msd 6al (I already had this), msds headers.
I do not plan on racing this car anymore, just spirited street driving.
tornik550   Should I get new carbs on my /6 2.2l 911e motor?   Nov 27 2014, 01:55 PM
type47   None of the above. I think you should do a single ...   Nov 27 2014, 04:50 PM
matthepcat   I agree with the above. I have a 2.2s motor with w...   Nov 27 2014, 05:19 PM
Mark Henry   Is it a running engine? If it is clean and get it...   Nov 27 2014, 05:29 PM
tornik550   The engine is a very clean, running engine. I sup...   Nov 27 2014, 05:43 PM
type47   I would like FI but $6500 is a lot of cash. ...   Nov 27 2014, 07:22 PM
johnhora   Is it a running engine? If it is clean and get i...   Nov 27 2014, 08:53 PM
ClayPerrine   If you were closer, I would help you with the MFI....   Nov 27 2014, 09:11 PM
Mark Henry   I see you have an ad wanting webers, I'd reall...   Nov 28 2014, 12:06 AM
roblav1   I am one of the guys who said that the Zeniths are...   Nov 28 2014, 12:34 AM
Tom_T   IMHO if it were mine then I'd go back to the M...   Nov 28 2014, 01:47 PM
mepstein   IMHO if it were mine then I'd go back to the ...   Nov 28 2014, 01:58 PM
JmuRiz   Never heard of people having issues with new PMO c...   Nov 28 2014, 02:46 PM
Mark Henry   Almost everyone that has issues with carbs have no...   Nov 28 2014, 03:47 PM
stownsen914   I'm a DIYer and have tuned PMOs and MFI on two...   Nov 29 2014, 07:12 AM
PancakePorsche   FWIW, I dicked for months trying to get a used set...   Dec 2 2014, 02:47 AM
9146986   Good carbs are not that difficult to tune, includi...   Dec 2 2014, 07:21 AM
- Lo-Fi Version Time is now: 2nd July 2025 - 01:42 PM
