FS: Front Sway Bar Adjustable Drop Links |
johnhora |
Nov 28 2014, 03:33 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
tach |
Dec 1 2014, 02:13 AM
Member Group: Members Posts: 79 Joined: 6-November 09 From: Minnesota Member No.: 11,016 Region Association: Upper MidWest |
Could you get the length between the two bolts hole centers and the bolt diameters. I need this info to make sure they will fit correctly.
johnhora |
Dec 1 2014, 10:51 AM
Could you get the length between the two bolts hole centers and the bolt diameters. I need this info to make sure they will fit correctly. tach... length is approx 190mm and the bolt holes ID are approx 10mm this is a Weltmeister adjustable drop link I have a stock drop link if that is what you need thanks...john |
B2524 |
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
John,
i'll take them if available. thanks k |
johnhora |
Dec 1 2014, 11:46 AM
B2524 sent you PM....thanks
johnhora |
Dec 1 2014, 12:30 PM
SOLD...Thanks
Paragon |
Dec 1 2014, 06:47 PM
Newbie Group: Members Posts: 49 Joined: 6-February 03 From: Corpus Christi, Texas Member No.: 255 Region Association: Southwest Region |
We stock the rubber/poly bushings for these if you need them...they're the primary wear item on these Weltmeister drop links.
johnhora |
Dec 1 2014, 09:15 PM
Hi Jason....thanks
Lo-Fi Version | Time is now: 6th May 2024 - 06:44 AM |
