FS: Front Sway Bar Adjustable Drop Links |
johnhora |
Nov 28 2014, 03:33 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
tach |
Dec 1 2014, 02:13 AM
Member Group: Members Posts: 79 Joined: 6-November 09 From: Minnesota Member No.: 11,016 Region Association: Upper MidWest |
Could you get the length between the two bolts hole centers and the bolt diameters. I need this info to make sure they will fit correctly.
johnhora |
Dec 1 2014, 10:51 AM
Could you get the length between the two bolts hole centers and the bolt diameters. I need this info to make sure they will fit correctly. tach... length is approx 190mm and the bolt holes ID are approx 10mm this is a Weltmeister adjustable drop link I have a stock drop link if that is what you need thanks...john |
Lo-Fi Version | Time is now: 27th May 2024 - 11:27 AM |
