| aircooledboy |
Nov 29 2014, 01:24 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" ![]() ![]() ![]() Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
In the final stages of re-assembly after flares & paint. I wired up the alt exactly the way it was when I took it out, and has always been, but I'm not showing any voltage change at the output pole whether the car is running or not. (IMG:style_emoticons/default/confused24.gif) I'm running the Renegade serpentine set up with AC on a 350.
I replaced the alt while I had the engine out with a higher amp unit because I've had charging "issues" with the car literally since I got it, (battery would slowly run down over time, and I've have to charge it), so I thought this might fix that. I've had the new one out and bench tested, and it's putting out 13.8v on the test stand. I'm using an alt for a 93 Buick, and historically it's only had the heavy wire from the output to the start, which then goes to the batt, and the lead on the plug which lights the idiot on the dash. When I start the car now, the idiot light goes out, but I'm only showing like 11.8-ish volts at the pole, and that doesn't change whether car on or not. Guy who built alt for me says as far as he knows, you must have 12v to the "red wire on the plug", which was never connected to anything before. After jumping that to 12v, no change. 11.7-ish volts, and car dies if I disconnect batt. Electrical is always my weak suit. Any ideas? HEEELLLP ME. . . . (IMG:style_emoticons/default/slits.gif) |
aircooledboy Need alternator advice from SBC V8 guys Nov 29 2014, 01:24 PM
Mike Bellis If 2 alternators act the same, the problem is with... Nov 29 2014, 01:42 PM
dakotaewing
If the ca... Nov 29 2014, 02:16 PM
rick 918-S If the bench test showed 13.8 the alternator is wo... Nov 29 2014, 02:58 PM
scotty b I've had charging "issues" with the ... Nov 29 2014, 03:14 PM
bulitt :agree:
You need to pull all the fuses.
Put a vo... Nov 29 2014, 03:33 PM
dwillouby
:agree:
Put a v... Dec 1 2014, 04:05 PM
jd74914 Good advice above...
Small hijack, but could you ... Nov 29 2014, 04:20 PM
aircooledboy
Small hijack, but could you... Nov 30 2014, 08:23 PM
Maltese Falcon Check your ground strap at the trans+trunk floor t... Nov 29 2014, 04:37 PM
Bruce Hinds
Check your ground strap at the trans+trunk floor ... Nov 29 2014, 08:44 PM
mikesmith Simple pic for 3-wire GM alternator here:
http://... Nov 29 2014, 04:37 PM
tooms351 yeah you hae to excite the alternator, I think you... Nov 29 2014, 07:30 PM
aircooledboy Sorry guys, I should have been more clear on the p... Nov 30 2014, 11:30 AM
Bruce Hinds Shouldn't need 3 fans . . . Nov 30 2014, 02:32 PM
Spoke
After jumping that to 12v, no change. 11.7-ish vo... Nov 30 2014, 03:54 PM
aircooledboy Bruce, the 3 fans are the standard Renegade set up... Nov 30 2014, 07:50 PM
Bruce Hinds
Bruce, the 3 fans are the standard Renegade set u... Nov 30 2014, 08:33 PM
drive-ability Sorry haven't red everything but since it seem... Nov 30 2014, 08:38 PM
aircooledboy Well this is embarrassing, but here goes:
My alte... Dec 8 2014, 09:15 PM
r_towle Why is your screen name aircooledboy? Dec 8 2014, 09:17 PM
aircooledboy
Ouch. I... Dec 9 2014, 11:29 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th September 2026 - 12:46 PM |
